mode actuator location and removal instructions needed
172,000 MILES • 4.2L • V6 • 4WD • AUTOMATIC
BRENDA DAY
which one is mode actuator and how to take it out?
Jul 4, 2021 at 4:28 AM
  • 110,248 POSTS
It is located under the dash on the left side of the HVAC unit. If you look below at pic 1, I highlighted the actuator and the arrow I highlighted indicates the front of the vehicle.
The remaining pics are the directions for removal and replacement. Once it is installed, you will need to calibrate it. I included those directions as well. You can do it using a scanner or without one. I included both.
Jul 4, 2021 at 2:55 PM
EUGENEVWONG
2007 Envoy SLT.
What is the OEM Part Number?
Sep 4, 2023 at 8:44 AM
  • 55,748 POSTS
Temperature Mode Valve Actuator Assembly - GM (89018365) here it is on the GM website:
https://www.gmpartsstore.com/oem-parts/gm-temperature-mode-valve-actuator-assembly-89018365?origin=pla&gclid=CjwKCAjwo9unBhBTEiwAipC11yIR3ky-ihQrn-MOwY3eoSKdaLzMULqad-LY_D-gHGx-sQGyGDK-ChoCNRYQAvD_BwE
Sep 5, 2023 at 4:10 AM
