Moaning sound when accelerating
200,000 MILES • AUTOMATIC
STEVEZIE
My car is making a loud moaning sound that increases in volume and intensity the faster I go, however it dissipates or gets quieter when I turn the wheel in either direction. I am not a car guy and could use any insight, do not want to dump a lot of money into it. Could it be bad wheel bearings?
Aug 30, 2019 at 5:34 AM
Good afternoon.
Yes, it could be but it could also be steering as well.
Could you upload a video of the noise so I can hear the noise?
Aug 30, 2019 at 5:45 AM
This sounds like a wheel bearing but normally they are described as a growling noise. However, the fact that it gets quieter when you make turns points to a wheel bearing.
Is it possible to get a recording of the noise so that I can make sure we are on the same page?
Aug 30, 2019 at 5:49 AM
STEVEZIE
This is the best I could do:
Aug 30, 2019 at 6:41 AM
Good. That sounds like the power steering pump whining.
Have you checked the fluid?
I would start by having the power steering flushed before talking about replacing the pump.
Aug 30, 2019 at 6:51 AM
STEVEZIE
Okay, thank you!
Aug 30, 2019 at 7:00 AM
You are welcome.
Always glad to help.
Aug 30, 2019 at 7:02 AM
