Our Volvo quit running. In trying to diagnose we discovered that all four cylinders have zero compression. The timing belt is in place and turning when starter is operated. When you turn the crank over with a wrench it stops and doesn't want to turn freely even with the plugs taken out. It stops about 180 degrees either direction. With the starter it will crank through. My question is, what marks are supposed to align on timing gears and crank to confirm whether or not the timing belt has jumped teeth? The marks on gears that I see don't seem to align with marks on timing cover as I would suspect. I have a feeling belt may have jumped a few teeth and since it's an interference engine it may be damaged.
Thanks
Thanks
Feb 24, 2019 at 10:30 PM
