MMI does not work?
2007 AUDI Q7
117,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
KIMOOOOOZ
  • 17 POSTS
Hello, is anybody can help me with the MMI?
Its working only for 2 sec and then turn off.
here is the VCDS report :
Sunday,26,November,2023,16:42:33:65284
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WA1BY74L87D066193 License Plate: AUDI Q7
Mileage: 189340km-117650mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 1E 28 2E 36 37 3E 42 46
4F 52 55 56 61 62 65 69 6D 6F 72
VIN: WA1BY74L87D066193 Mileage: 189340km-117650miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
3E-Media Player 4 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 00 0447
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 00999 444 64523
VCID: 688AB1724E7C2B0A873-803C
VINID: 9D1052A4711C2075001860490CE70BF868
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4010430
Coding: 0000002
Shop #: WSC 31414 790 00001
VCID: 290CF47695F6D20258D-807C
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 280AF1728EFCEB0A473-807C
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 13:22:35
Freeze Frame:
Count: 64
Count: 14593
Count: 128
Count: 34304
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:05:20
Freeze Frame:
Count: 0
Count: 8449
Count: 129
Count: 59648
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 13:06:35
Freeze Frame:
Count: 128
Count: 12545
Count: 297
Count: 50432
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100600333
Coding: 0000131
VCID: 6390A65EB75A4852521-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 08: Auto HVAC Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030070048
Coding: 0786470
Shop #: WSC 03323 444 54512
VCID: 619CAC56AD465A4240D-8034
3 Faults Found:
01273 - Fresh Air Blower (V2)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:04
Freeze Frame:
Temperature: 17.0°C
Speed: 0.0 km/h
(no units): 0.0
(no units): 63.0
02874 - Control Module 2 for Central Convenience (J773)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:09
Freeze Frame:
ON
02380 - Positioning Motor for Right Side Vent (V300)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:09
Freeze Frame:
Voltage: 13.70 V
Temperature: 16.0°C
(no units): 100.0
(no units): 112.0
Temperature: 11.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0004013
VCID: 313C1C16BD26AAC290D-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00062431
Shop #: WSC 31414
1 Fault Found:
01520 - Rain and Light Recognition Sensor (G397)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 4
Reset counter: 100
Mileage: 189340 km
Time Indication: 0
Date: 2006.11.23
Time: 12:12:00
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD043VXZ
Coding: 0014131
VCID: 2B000E7E9F0AC012AA1-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME19370A139
Subsystem 3 - Serial number: 6342QSME19392533B
Subsystem 4 - Serial number: 6352QSME18282059C
Subsystem 5 - Serial number: 6362QSME18271769J
Subsystem 6 - Serial number: 63734SME18094605Y
Subsystem 7 - Serial number: 63834SME18021C69+
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063130488
Coding: 0002042
VCID: 6696BF4A44683D7AB5F-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0170
Revision: 00700000 Serial number: 5HH58RMC6
Coding: 2641268
Shop #: WSC 53116 067 57207
VCID: 2310E65EF7DA0852121-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B07808F
Coding: E7F7BE77E02B00
Shop #: WSC 12345 123 12345
VCID: 6C82CD625A84072AE3B-8038
Address 1E: Media Player 2
Cannot be reached
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000136768
Coding: 0000006
Shop #: WSC 00000 000 00000
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:09
Freeze Frame:
ON
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:14
Freeze Frame:
ON
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
Address 37: Navigation
Cannot be reached
Address 3E: Media Player 4
Cannot be reached
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0035531
VCID: 2F381A6EAB12BC32869-807A
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01010800080000
Coding: 4464649
3 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 100
Mileage: 146372 km
Time Indication: 0
Date: 2017.10.06
Time: 16:03:24
00930 - Locking Module for Central Locking; Rear Left (F222)
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 96
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 15:35:46
02956 - Lamp in Trunk/Hatch Lid; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 100
Mileage: 189342 km
Time Indication: 0
Date: 2006.11.26
Time: 18:45:11
Freeze Frame:
Bin. Bits: 000 001
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000055787
Coding: 0012001
VCID: 5EE697AA9C3865BA7DF-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0035531
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000062755
Shop #: WSC 53116 001 104857
VCID: 6492A542B2544F6AABB-8030
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 00915105AH
Coding: 344630393135313035432056413030303931353130354148
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0000002
Address 65: Tire Pressure Labels: 4F0-910-273-BA.clb
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900036053
Coding: 0143333
VCID: 221EE35AE8C0015A197-8076
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 13:38:22
Freeze Frame:
(no units): 0.0
Voltage: 14.00 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 13:38:22
Freeze Frame:
(no units): 0.0
Voltage: 14.00 V
(no units): 142.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000002
VCID: 2412E542F2D40F6A6BB-8070
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD16.11.06--H21001001A0036ÿ
Subsystem 4 - Serial number: 1A0036ÿ
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 139
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 14:24:26
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002186110-----
Coding: 0003855
VCID: 2616FF4A84E8FD7A75F-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
2 Faults Found:
01512 - Control Module for Sliding Roof
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:04
02907 - Control Module for Roof Shade (J394)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 100
Mileage: 189341 km
Time Indication: 0
Date: 2006.11.23
Time: 12:36:04
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
End----------(Elapsed Time: 01:54, VBatt start/end: 14.0V/14.0V)-----------
Dec 6, 2023 at 8:41 AM
