The door only sounds like that and that is it. they are not fuses and is not a window motor.
Jan 20, 2020 at 2:45 AM
✓Experienced Mechanic
It sounds like a ground or the window switch is not working. To be sure here is the window wiring diagrams and a guide to help you check for power and ground and to be able to see how the system works:
