MK 808s scanner can I use this scanner to bleed my ABS module with a motive power bleeder?
141,295 MILES • 4.6L • V8 • 2WD • MANUAL
BRIANRIVERA17
Hey, just have a quick question regarding the MK 807s scanner. Can I use this scanner to bleed my ABS module with a motive power bleeder? Or is it required to have someone pump the brakes instead?
May 13, 2024 at 8:25 AM
STEVE W.
  • 15,418 POSTS
It has bi-directional control so it should have the brake bleeding function in the menu. However, if you have not bought one you could opt to get FORScan for windows and the correct dongle and have a scan tool that handles Ford and many Mazda's at the same level as the OEM scan tool for far less money.
https://forscan.org/home.html
May 13, 2024 at 9:52 PM
