1995 Mitsubishi Truck engine idle
203,000 MILES • 4 CYL • 2WD • MANUAL
ELKHUNT
When I first come to a stop the engine idle down like it is going to die then in a few seconds it gose back to a normal idle. It dose this when I first start the truck too.
I did a new battery because it just die.
Dec 15, 2009 at 1:23 PM
  • 110,248 POSTS
Have you checked for vacuum leaks? Also, has the check engine light ever come on while it was running?
Dec 15, 2009 at 1:28 PM
ELKHUNT
I have not checked for vacuum leaks. The check engine light has not come on.
Dec 15, 2009 at 1:32 PM
  • 110,248 POSTS
I would start with that. Check for vacuum leaks and let me know what you find.
Thanks for using 2carpros.com.
Dec 16, 2009 at 12:43 PM
