1995 Mitsubishi Truck
188,000 MILES • 4 CYL • 2WD • AUTOMATIC
ANDREAL_GARNER
My truck window got smashed in and I need to replace it. The windows are not automatic, but manual, and I'm sure it's simple to replace. But i'm unsure of how to do it. How do I change my driver's side window?
Jan 22, 2010 at 7:19 AM
BILLYMAC
  • 2,204 POSTS
Hi
remove the door handle.
remove the window crank
remove the door panel
roll the window up until you can see the base of the broken window.
remove the nuts holding it to the regulator.
remove this piece.
install your used window on this part unless new one has it. bolt back in . replace panel..
simple please vote billymac
Jan 22, 2010 at 12:29 PM
