1992 Mitsubishi Truck no start
120,000 MILES • 4 CYL • 2WD • MANUAL
SICK OF IT
Th.e truck cranks and cranks and cranks, but won't fire,. We have spark. We have rotor pointing to number one dist. terminal when number one cyc. is at top dead center on compression stroke. Timing belt is in tact. We have fuel at fuel rail. We have compression readings of around 150 lbs. Appears to be flooding badly. With spark plugs out and cranking the engine we get fuel spray out the plug holes. Also while cranking with plugs in we get fuel soaking at the exaust flange at mfld. Truck has flooded before, but cleared up for a while. Now it just won't fiire. Thank-you
Jan 21, 2010 at 10:35 AM
  • 75,988 POSTS
Hi sick of it, Welcome to 2carpros and TY for the donation
Check the fuel pressure with a fuel pressure gauge designed for your fuel system it should be 38psi idling w/vacu and w/o vac 47-50psi.
If excessive check the fuel return line if its clogged-up also check the fuel pressure regulator could be ruptured diagphram and injectors leaking
Jan 21, 2010 at 11:10 AM
