1992 Mitsubishi Truck dodge ram 50
120,000 MILES • 4 CYL • 2WD • MANUAL
SPIKE9163
the 2.4l will not start on cold start til u try cranking a few times {start and die} put new cold start sensor did not help. new plugs,wiring,did not help. new fuel pump did not help. can not give it gas until it engine heats up{it will flood out} could this be the distrbutor shift. this engine is in a 1992 dodge ram 50.
Dec 10, 2009 at 1:03 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe weak coil output hold plug wire next to block 1/4" need blue/white spark. also dist cap and rotor check contacts for corroded terminal ends.
Let me know
Thnaks for donate
Dec 10, 2009 at 6:53 AM
