1991 Mitsubishi Truck will not startwhen cold
114,800 MILES • 4 CYL • 2WD • MANUAL
TALMADGE WARD
1991 mighty max when cold will not start I have tried all of the normal things like computor repair,sensors,idle componts. When temp is aboue 50 starts ok.??? Tks
Dec 3, 2009 at 11:05 AM
  • 75,988 POSTS
Do below to determine if its fuel or spark related something has to give here Hot or Cold
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Dec 3, 2009 at 10:22 PM
