1990 Mitsubishi Truck engine starts and stops
1990 MITSUBISHI TRUCK
137,000 MILES • 4 CYL • 2WD • MANUAL
FIX IT SHOPP
How to test fuel pump on 1990 Mitsubishi truck 2.4 engine fuel pump in tank ? Truck runs fine as long as I pour gas in throttle body.Truck will cvrank and idle then cut off, can't speed engine up.
May 25, 2010 at 2:52 PM
DOCFIXIT
  • 18,828 POSTS
Use test light to see if injector is getting power. To test pressure need adaptor hook up as in diagram 38 psi. Can you hear pump ? checked voltage to pump?
May 26, 2010 at 2:53 AM
