1987 Mitsubishi Truck Crank Pulley
1987 MITSUBISHI TRUCK
MANZO
Engine Mechanical problem
1987 Mitsubishi Truck 4 cyl Two Wheel Drive 34567 miles
If I Put The Wrong Crank Pulley In My Truck What Could Happen....
Jun 8, 2009 at 3:59 PM
Changing the original crankshaft pulley can have negative effects if the replacement pulley is not manufactured properly. A crankshaft or accessory pulley that is not machined or balanced properly can cause severe damage. For most domestic V8s a harmonic damper is necessary to absorb crankshaft vibrations. Early to mid-year V8's kept the pulley and damper as separate components. Most late model V8s now integrate the damper and the pulley into one part. For small displacement engines found in many import and domestic vehicles (4.0L and under) the original crankshaft pulley only serves to quiet noise vibration and harshness (NVH) you hear in the occupant compartment. Although it may look like a damper on V8's engines it serves no protection function to the engine.
Jun 8, 2009 at 6:37 PM
