1997 Mitsubishi Triton cant get engine to fire
ROBTER666
Electrical problem
1997 Mitsubishi Triton 4 cyl Four Wheel Drive Manual
i cannot get any spark from the coil everything else is working fine. I am not sure if i have wired it correctly because when i bought it the engine had been changed from a deisel engine and most of the wireing had been chopped out
Dec 19, 2009 at 12:36 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 19, 2009 at 5:23 PM
