1987 Mitsubishi Starion
196,000 MILES • 4 CYL • 2WD • AUTOMATIC
ILLINI90
The car will start but has little power when moving and doesnt sound right. It kind of sounds like a go cart when its running now. the oil pressure gauge is also reading zero while it is running.
Oct 30, 2010 at 9:55 AM
KHLOW2008
  • 41,812 POSTS
Hi illini90,
Low power, oil pressure and abnormal noises indicates a possible fault with the engine and lubricating system. Possibly a faulty oil pump.
Did you check the oil level?
Oct 30, 2010 at 9:27 PM
ILLINI90
the oil level is good its just that there is no oil pressure
Oct 31, 2010 at 8:46 AM
KHLOW2008
  • 41,812 POSTS
The oil pump is driven by the counter balance shaft drive belt and I believe the belt has failed. You would need to remove the timing belt cover to inspect. .
Nov 1, 2010 at 12:38 AM
