1990 Mitsubishi Pajero cAR REPAIR MANUAL
1990 MITSUBISHI PAJERO
109,347 MILES • 4 CYL • 4WD • MANUAL
INFOJONSER
Please help me make sure I get the correct repair manual.
It is a Left hand drive 2600 Standard model
Haynes is sugesting I use manula #68040 which covers "Mitsubishi Pick-ups & Montero Haynes Repair Manual for 1983 thru 1996 covering 2WD & 4WD models with gasoline engines Pick-ups (1983 thru 1996) Montero (1983 thru 1993)"
Sep 20, 2010 at 11:58 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
As there was 5 engine variations in this model you will have top check your engine code with what the manual covers, the engine code is stamped on the compliance plate under the bonnet, match that with what the book covers and you will not have a problem, don't get confused with model names, they change from country to country.
mark (mhpautos)
Sep 24, 2010 at 4:52 AM
