2004 Mitsubishi Outlander leaking ac
2004 MITSUBISHI OUTLANDER
11,000 MILES • 4 CYL • FWD • AUTOMATIC
KRAEMER
I just had my airconditoner fixed and under the dash would leak and cause a wet floor. They replaced the blower and hose. It has worked for 3 weeks and tonight after a long drive I stopped at light and started leaking again. I would hear the swooshing. Same sounds, same problem. I had previoulsy had the compressor switch replaced. This is the 2nd repair and 700 dollars and problem is still happening.
May 15, 2010 at 7:52 PM
LFOGLE
  • 5 POSTS
I have the same problem with my 2003 Outlander. On advice from my dealer I will be checking the condensor drain located under the hood on the firewall. Should be a black hose elbow about 3/8 diameter.
Jul 12, 2010 at 2:25 PM
