2003 Mitsubishi Outlander water leaking
2003 MITSUBISHI OUTLANDER
SHALECE
Air Conditioning problem
2003 Mitsubishi Outlander Two Wheel Drive Automatic
There is water leaking into my car on the passenger side near the feet. My hubsand asked the mechanic and he said that because the water is cold, no smell, that the is probably condensation from the air conditioning. He said there is a rubber tube that may just be backed up and that's it's really easy to unclog, just crawl under the car etc. Anyways they tried but couldn't find the tube. Can someone help how to locate it on a Mitsubishi Outlander?
Thank a million!
Sep 29, 2008 at 10:20 AM
LFOGLE
  • 5 POSTS
I have the same problem with my 2003 Outlander. On advice from my dealer I will be checking the condensor drain located under the hood on the firewall. Should be a black hose elbow about 3/8 diameter.
Jul 12, 2010 at 7:42 AM
