white smoke from front hood of car?
MITSUBISHI
YAYITSKATE
99 gallant, 47k miles. after driving for 5 minutes I noticed white steam coming from the left side of the front hood. There was also a bad smell coming from there, kind of like burning rubber but not exactly. Car was not overheated, I checked. What can be the problem?
Jul 19, 2006 at 1:24 PM
BURRELLD
  • 7 POSTS
Did you check the belts? A loose belt will slip and produce smoke, plus give off a burning rubber smell because that's just what is happening.
Sometimes too, a pulley, for the alternator, power steering, etc. will freeze up and the belt will melt while going over the stuck pulley.
Check the belts first and then check and make sure all of your belt driven pulleys are moving freely.
Nov 20, 2006 at 1:42 AM
RLA94501
I have the same problem. Is it drivable. at that point? My car started to smoke the minute I parked the car.
Apr 3, 2007 at 9:31 AM
BURRELLD
  • 7 POSTS
Anytime smoke, or steam, is coming out of the engine compartment, it is best to shut the engine down, let it cool, and then find out what the problem is before starting the engine again.
It could be a bad belt, pulley, radiator leak, burning wires, etc. Its best not to compound any small problem by running the engine until you discover the possible source of the steam or smoke, because you could turn it into a major or dangerous problem.
One time I had smoke coming out of the engine compartment, with a "rubber" type smell. Upon checking it out I found that a plastic shopping bag had been sucked up off of the highway onto the exhaust manifold. Once the bag was removed, and all of the plastic finally burned off, the "problem" stopped.
Apr 3, 2007 at 10:48 AM
OQUINT
White Smoke?
Perhaps your engine has elected a new Pope?
Apr 8, 2007 at 11:00 AM
