When In neutral and i push my car it makes a popping or clic
MITSUBISHI
BUD1984
I have a 95 Mitsibushi Diamante ES with about 190000 miles with an V6 engine. I would like to know the reason that when i put my car in neutral and give it a push a clicking noise occurs. But when I look at my CV Joint it seems okay. Once before i replaced a bolt on some type of bracket which i think gave support to the CV Joint because it was doing the same thing but i do not know what it is called. Do you know what is the name of the bracket and what may be wrong with my car?
Oct 31, 2007 at 6:41 AM
  • 75,988 POSTS
Its called the center bearing bracket see below is this the one you talking about. This the only bracket involved on the half shafts.
https://images.2carpros.com/forum/automotive_pictures/12900_bracket_1.jpg
Oct 31, 2007 at 9:33 AM
RAYT333
  • 27 POSTS
Does your car have a posi or limited slip differential?
That will cause noise when moving if you are making a turn
Nov 18, 2007 at 8:34 AM
