I Just got my engine back from the machine shop after installing all this...wisco piston, eagle rods, 4g64 crank and a balance shaft ellimator kit thats all for the block for the head i got duel valve spring 1mm over size valves, new lifters.. after everything was assembled the car wont start the timing is dead on, the #1 cilinder is on tdc, I get spark and also get fuel all the vacumes are all hoocked up and all the grounds are also hooked up i got a 1997 eclipse 4g63 turbo engine...
Nov 22, 2007 at 1:11 AM
