Overheating problem
MITSUBISHI
AITCHDITTO718
i have a 95' Mitsu Eclipse 2.0 non turbo. the overflow bottle use to overheat all the time until i changed the thermostat. since i have changed the t-stat, smoke has been coming from below the overflow bottle. (not the bottle itself) my guess is the water pump. could that be the problem because i have been wasting alot money?
Aug 14, 2007 at 5:29 AM
  • 75,988 POSTS
[quote:67b06a448b="aitchditto718"]i have a 95' Mitsu Eclipse 2.0 non turbo. the overflow bottle use to overheat all the time until i changed the thermostat. since i have changed the t-stat, smoke has been coming from below the overflow bottle. (not the bottle itself) my guess is the water pump. could that be the problem because i have been wasting alot money?[/quote:67b06a448b]
Try this warm up the engine while running squeeze the upper hose then let go did the flow increases-if so, for a cheap fix-replace the radiator cap and see what happens.
Aug 14, 2007 at 11:13 AM
AITCHDITTO718
[quote:c6029987af="rasmataz"][quote:c6029987af="aitchditto718"]i have a 95' Mitsu Eclipse 2.0 non turbo. the overflow bottle use to overheat all the time until i changed the thermostat. since i have changed the t-stat, smoke has been coming from below the overflow bottle. (not the bottle itself) my guess is the water pump. could that be the problem because i have been wasting alot money?[/quote:c6029987af]
Try this warm up the engine while running squeeze the upper hose then let go did the flow increases-if so, for a cheap fix-replace the radiator cap and see what happens.[/quote:c6029987af]
How could replacing the cap stop the smoke? The smoke smells like boiling water. Thats why i think or thought it was the water pump. I would love to replace the cap for cheaper fix but i just want to know what it does for the radiator.
Thank you for your response
Aug 15, 2007 at 4:47 PM
