over heating problem
MITSUBISHI
JAYMAN14
1997 mitsubishi eclipse 2.0 DOHC 140,000k MT
Today on my way to school my car began to overheat so i turned around to go back to the store for water. As i turned around it went dead. I allowed it to cool for about 15 minutes and added some coolant/water mixture i had in the trunk. Afterwards i tried to start, but the engine would not crank. Any possible ideas?
Oct 18, 2007 at 4:01 AM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Thu Oct 18, 2007 10:11 am
Subject: plz help
Its probably hydrolocked-try removing all the plugs and check for water in the cylinders. Is your battery and connections good?
Lets do below to rule out the headgasket/head and block.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
Oct 18, 2007 at 8:30 AM
JAYMAN14
so u think it is a blown head gasket?
Oct 18, 2007 at 12:18 PM
  • 75,988 POSTS
The only way to tell is thru the block and pressure tests.
Oct 18, 2007 at 3:05 PM
JAYMAN14
on average what would be a normal price for these tests?
Oct 18, 2007 at 3:53 PM
  • 75,988 POSTS
Its about 7hrs labor time
Gasket itself $55-60
Labor rate: $70-$125.00 per hr
Oct 18, 2007 at 6:26 PM
