I have a 1996 Mitsu Eclipse,my check engine light came on, I checked codes two different ways, I done the key off and on 5 times, it was a code 32 open or shorted circuit in EGR solonoid, and I pulled codes with my scan tool it was P0401 EGR insufficient flow, I got a flow chart from Alldata, I checked power and ground, resistance of the solonoid and wires, checked connections/connectors,and checked EGR valve and tube and I cleaned it, after everything tested ok it said to replace the PCM, well I have 4 Eclipse"s, so it didn"t cost me any money, so I replaced it, the code came back, so what else should I do
Dec 3, 2006 at 12:47 PM
