miss fire past half throttle?!?!
MITSUBISHI
EAGLETALONTSI
I have a 97 mitsu eclipse with 159,000 miles on it. The motor is a 4 cylinder, the 420a non-turbo. I bought the car a month ago. The car is sending a cylinder miss fire 1 and a mult./random cylinder missfire code. I had a small shop that changed the ecu and the cam position senor 3 weeks ago. The cars issue is that when you go to give the car more than half throttle it will miss fires and wont put up speed. i then had a mitsu dealer look at it and they told me there was water in the tank also so they drained it and etc. also they told me the ecu wasn't the right one or wasn't working rite. they wanted 1300 bucks to put a new one in soo i got the car back. I then startedmessing around with the car one night and unplugged the coolant temp senor and there was no issue with the miss firing passed half throttle. iam unclueless on what it could be. Could the ecu need reflashed? Could it be a head gasket going out? I would greatly appreciate any ideas on what this could be. Thank you very much for your time.
Jun 8, 2007 at 11:30 AM
JAVA MOTORSPORTS
  • 52 POSTS
Replace your coolant temp sensor. The ecu reads the temp of the engine and tells the airflow sensors how much air to put in to the engine. If the sensor is not working then this could cause the missfire. I have a 1998 Mitsubishi eclipse and had the same problem and a temp sensor fixed it . If you have any problems or need anything you can e-mail me.
Jun 8, 2007 at 9:00 PM
