master cylinder
MITSUBISHI
MRTHET
I have a 91 mitsubishi eclipse 2.0 turbo that has a bad master cylinder, first of all where is that located, second my friend has a 91 plymouth laser 2.0 non turbo that doesnt run, could I swap that master cylinders?
Jul 11, 2007 at 5:59 AM
JAVA MOTORSPORTS
  • 52 POSTS
The Master cylinder is under the hood right in front of the steering wheel on the firewall. It is the thing you put brake fluid in. And I am not real sure as to the lazer master cylinder working on your car. I would take your Master cylinder off and take it to see if thay look the same.
Jul 11, 2007 at 6:25 AM
MRTHET
Ok he says it was pretty new, so i would assume it works, but i took off the hoses and when i tried to take off the 2 brake lines, the wrench i had fit perfect, but it would just start to strip it out, am i taking off the bolts wrong?
Jul 11, 2007 at 6:44 AM
JAVA MOTORSPORTS
  • 52 POSTS
No it is not anything you are doing wrong. You need a line wrench, it looks like a boxed in with a notch cut out so you can get the wrench over the line. If that don't work then you can use a pair of vise grips. but only use the vise grips if you have to because it can cause some pretty bad damage.
Jul 12, 2007 at 4:26 AM
