knocking in engine
MITSUBISHI
GLEN_9887
my 03 galant 4cyl engine began knocking the other day and the check engine light came on and today it just wont start. could you tell me what's wrong and how much it would cost to fix.
May 30, 2007 at 4:13 AM
JAVA MOTORSPORTS
  • 52 POSTS
My question is will the engine turn over or is it locked up? If it turns over but will not start you could have had an oil pump fail and burned you pistons. If that is the case replace the whole engine as in the long run it will cost just as much. If it will not turn over at all then the engine is locked up { for the same reason above } Still i found that it was cheaper to replace the whole engine in my Eclipse than to fix the old one.
May 30, 2007 at 6:25 AM
