I sent Pm's helping others 2day Now I need help some help
MITSUBISHI
STANGBANGER
Q... 1995 Mitsubishi Galant ES with AT , do I need to Remove the engine to remove the water pump?
I seen one reply to this same Q but I dont see how this can happen just by slightly lifting the motor.
I did slighltly have to lift the engine just to gain access to the upper pulley bolts. About 2 1/2 " in all.
I have removed a great deal of stuff to gain as much access to the pump as I can but Now it seems that I need to remove the Timing belt Black plastic cover to gain access to the remaining water pump bolts and looks like to me that there may well be a few inslde this cover?
I removed the D/S Engine mount to lift the engine up slightly but still cant get the Timing cover off and seems that the harmonic balancer (lower Crank Pulley) needs to come off as well to remove the cover to gain access to the water pump bolts. Is this true as well? And if not true how do I remove the Timing cover and lower pulley with engine still in car?
Am I doing this all wrong or will the engine need to either be removed or lifted to such a high point as to clear the strut tower to gain access to remove the lower pullie?
Sorry I just dont know and need some good advice. This is my first import FWD I have worked on and its got me a bit confused.
Thanks
Tom A.
Jan 22, 2007 at 1:08 PM
  • 55,616 POSTS
Yep, you need to remove the lower pully, the remainder of mounting bolts are behind the timng cover, in addition to raising the engine you might need to lower it also. We have a special puller to remove the bottom pully in the car, here at the shop. Please let me know how it goes.
Jan 25, 2007 at 2:27 AM
STANGBANGER
Thanks for your reply with direction. It helps out 100% now . I will be back at it this weekend again so I will post how it went.
Q.... Will I need to remove all Engine mounts to lift or just certain mounts?
I already did the mount on the Drivers side ONLY.
Thanks again:-)
Jan 25, 2007 at 9:01 AM
  • 55,616 POSTS
just certain mounts. pelase let me know how it goes :D
Jan 25, 2007 at 10:26 AM
