The computer in these vehicles is a possibility. They seem prone to failure at times, but, there is a troubleshooting procedure for ignition problems. You should have the ignition properly diagnosed to confirm it is in fact the computer for, there are other components that can cause a no start. If you are a DIYer, with a detailed repair manual and a multimeter, backprobing the harness to the computer can be done with these items in lieu of a breakout box if neccessary. Testing procedures for the ignition curcuit and components can eliminate components that are within range per manufacturers specs.
However, I would suggest a reputable repair center if you are not mechanically inclined.
SPONSORED LINKS
Sunday, May 6th, 2007 AT 1:45 PM
