1991 Mitsubishi 3000GT Fuel Pump
MITSUBISHI
GRH
how do u check if good fuel pump on 91 3000gt
Jul 20, 2007 at 10:31 AM
  • 75,988 POSTS
If its an EFI system-you should hear the pump come On when ignition key is at On position for a few secs. Do you have this? If it comes On-check the fuel pressure-without the proper pressure she won't start it has to have it.
If it doesn't look for power at the f/pump connector. If you got it there-could be a grounding problem or the pump itself.If not take it back to the fuel pump relay, not there-its coming from the computer or a voltage drop problem.
Jul 20, 2007 at 8:45 PM
Suggested Repair
With the key on, listen for the fuel pump to prime for a few seconds. If it primes, check fuel pressure. If it does not, check for power at the pump connector; power with no operation points to a ground or the pump. If there is no power, check the fuel pump relay, then the computer feed or a voltage drop.
Conversation Summary
The owner of a 1991 Mitsubishi 3000GT asked how to tell whether the fuel pump is good. The expert said an EFI pump should be heard priming briefly with the key on. If it primes, fuel pressure should be checked because low pressure can prevent starting. If it does not prime, power at the pump connector, the ground, the pump, the fuel pump relay, the computer, and possible voltage drop should be checked in that order.
