1992 Mitsubishi Galant Engine Miss
MITSUBISHI
PWT905
1992 mitsubishi galant 2.0 automatic
81,000 miles
I have a miss in the motor, I replaced the cap, rotor,
plugs and wires. the car did have the wrong rotor in it for that year. I thought for sure that was it.
It seems to not be as bad above 2000 rpm/
Is there a sensor I should trouble shoot
thanks
Aug 23, 2006 at 7:42 AM
MIKEYBDMAN
  • 623 POSTS
[quote:343ed9b204="pwt905"]1992 mitsubishi galant 2.0 automatic
81,000 miles
thanks
Joe[/quote:343ed9b204]
When you replaced the plugs, did one cylinder plug look fouled, or have a build up on it?
Here is what I would do. Find out which cylinder is missing. This can be done by disconnecting each plug wire one at a time and placing one of your old plugs in that plug wire laying on the engine block. This will do two things...first it will tell u if that cylinder is the one missing because the car will not get worst. Secondly you will be able to see if that plug is firing. Do this to each cylinder until you find the one that is missing. If the plug is firing, I would suspect a bad fuel injector at that clyinder. If the plug is not firing, then track back and see where you are loosing fire for that cylinder.
On a side note, a compression check could ease your mind on the internal workings of the engine.
Aug 23, 2006 at 8:57 AM
Suggested Repair
Isolate the missing cylinder by grounding an old plug in each wire one at a time. If that plug fires, suspect the fuel injector; if it does not, trace the loss of spark. Also perform a compression check.
Conversation Summary
A 1992 Mitsubishi Galant 2.0 with 81,000 miles has an engine miss that is less noticeable above 2000 rpm. Cap, rotor, plugs, and wires were replaced, including a wrong rotor, without curing it. The expert advised identifying the weak cylinder with a grounded test plug, then checking spark or the injector, and doing a compression test.
