ECU Computer
MITSUBISHI
DADDYNICK2005
Will A ECU Computer Work On Eclipse A 2.4 4Cylinder Out Of A Eclipse 3.0 v6
Aug 13, 2007 at 9:37 AM
  • 75,988 POSTS
[quote:f5507d5613="daddynick2005"]Will A ECU Computer Work On Eclipse A 2.4 4Cylinder Out Of A Eclipse 3.0 v6[/quote:f5507d5613]
I don't think so-ECU/ECM/PCM are programmed differently according to its configurations-
Hence: The computer you are about to use is for a V6, again I might be wrong-you can call it in and match all the numbers. In the event you decide to use it, -it will fry something up.
Good Luck
Aug 13, 2007 at 7:18 PM
DLAPARRA
i have a mitsubishi lancer ralliart 04, and it has problems with trhottle position sensor, its broken, i need to buy a new tps but i can`t found
can you help me?
Aug 14, 2007 at 1:20 PM
