Chronic battery drain
MITSUBISHI
CO_GOONER
Mitsubishi Galant GS
2003
49,350
2.4l 4 cyl
I am having a frustrating time with my Galant. The battery simply will not hold a charge. Jump started it last night at my friends house and he ran a voltmeter across the battery and it showed just over 14 volts, so presuming that the alternator is fine. When I switch off the engine however the power just drains out of the battery, and if I try to start it 30 secs after switching it off then it just clicks. My friend (who is a bit more knowledgable than I) was guessing that either it is a bad diode somewhere or something is shorting out and causing the battery to drain almost instantly. Do either of these sound plausible and if so, how can I check to narrow down the problem? Any other thoughts as to what the culprit might be?
Thanks in advance
david
Jul 30, 2007 at 5:58 AM
MITSUTECH
  • 17 POSTS
first you need to make sure the battery is good. if so you need to check for a short. you need an amp meter . remove neg cable put one lead on cable and other on neg side of battery. should not have more .0050 of amp if over 1/2 amp is too much. pull fuses one at a time to untill 1/2 amp and lower. that part of curicut is the problem. then need to trace out the problem.
Sep 1, 2007 at 3:35 PM
