I see the check engine light on, I can't smell anything all parts seem to be functioning. 1995 Mistsubishi expo, 130,789 miles.
Jan 6, 2007 at 9:08 AM
Retrieve the diagnostic trouble codes. An emissions-related sensor fault can force default fuel-air adjustments, trigger the check engine light, and reduce fuel mileage.
The owner of a 1995 Mitsubishi Expo with 130,789 miles reports a check engine light but no unusual smell and no obvious part failure. The expert says an emissions problem, such as a failing sensor, can cause the computer to use default fuel-air settings, illuminate the light, and affect mileage. The next step is to retrieve the codes.
