1995 Mitsubishi Expo Check Engine Light
MITSUBISHI
SNELLING42
I see the check engine light on, I can't smell anything all parts seem to be functioning. 1995 Mistsubishi expo, 130,789 miles.
Jan 6, 2007 at 9:08 AM
SERVICE WRITER
  • 9,123 POSTS
There is something affecting the emissions. If a sensor is going out of whack for example, the computer will use a default to make adjustments to the fuel/air ratio. It will trigger the cel to lite up. Your gas miliege is probably being affected. FInd the codes and we can go from there.
Jan 6, 2007 at 10:28 AM
Suggested Repair
Retrieve the diagnostic trouble codes. An emissions-related sensor fault can force default fuel-air adjustments, trigger the check engine light, and reduce fuel mileage.
Conversation Summary
The owner of a 1995 Mitsubishi Expo with 130,789 miles reports a check engine light but no unusual smell and no obvious part failure. The expert says an emissions problem, such as a failing sensor, can cause the computer to use default fuel-air settings, illuminate the light, and affect mileage. The next step is to retrieve the codes.
