Changing timing belt
MITSUBISHI
KAMALROJA
My Mitsubishi Galant ES ran 101K miles now. I was supposed to have changed my timing belt at 100K miles. Now do I need to change the water pump also when I change the timing belt?
Jun 10, 2006 at 8:51 AM
STANGBANGER
To get the water pump off you need to get the Timing cover off as well so that why its a good idea to swap em out at the same time. Its not a 123 easy job and will take some time to R&R (remove and replace) this stuff.
Good luck.
Stangbanger
Jan 25, 2007 at 11:21 AM
