1998 Mitsubishi Eclipse, 140,000 miles.
AAMCO Rebuilt transmission a couple of years ago.
After the car sits for 2 days or more, it sometimes
will not crank when the key is turned to the
start position. If you wait awhile, like several minutes to several hours, it will crank and start. Sometimes it will go a week or more without acting up and then it will refuse to crank for a short time. All the accessories come on when the ignition switch is on but when it acts up, there is no sound when turning the switch to the start position such as would be heard if a solenoid or relay is engaging. What would be the most likely cause or what can I do to narrow it down.
Thanks,
Mark
Thanks,
Mark
Oct 23, 2007 at 1:57 PM
