car stalls
MITSUBISHI
DMPRAG01
2001 eclipse gt 3.0l 6 cylinder 133000 miles. car stalls when the a/c is turned on when stopped. If driving a/c can be run but when it slows down to a stop the car will stall. Any thoughts on what could be causing this?
thanks for the help
Nov 10, 2007 at 12:19 PM
Could be an idle up vacuum switching solenoid, the idle air control valve or the computer.
The computer when it receives an AC signal when the compressor kick in it will command the idle air control to increase the idle due to the load of the compressor. or a vacuum switching solenoid to raise the idle.
Nov 11, 2007 at 11:59 AM
DMPRAG01
how could i figure out which one it is or if it's all 3? thanks for the help so far
Nov 11, 2007 at 1:15 PM
