2002 Mitsubishi Galant Brake Light
MITSUBISHI
LOUPAL
2002 galant 4 cylinder 106k miles , i need to change the break light on my car, how do i access the bulb that needs to be replaced?
Aug 14, 2007 at 4:06 AM
  • 75,988 POSTS
[quote:75a8e4ebaf="loupal"]2002 galant 4 cylinder 106k miles , i need to change the break light on my car, how do i access the bulb that needs to be replaced?[/quote:75a8e4ebaf]
If you don't see any screws from the outside of the lenses-you have to go thru the trunk could be a snap on clip or a screw securing it from the inside
Aug 14, 2007 at 11:23 AM
Suggested Repair
If there are no screws on the outside of the brake light lens, access the bulb from inside the trunk. Look for a snap-on clip or a screw securing the lamp assembly from the inside.
Conversation Summary
The owner of a 2002 Mitsubishi Galant with 106,000 miles asked how to access a brake light bulb for replacement. The expert advised checking for exterior lens screws; if none are present, the bulb is reached through the trunk, where a snap-on clip or interior screw may hold the assembly.
