2003 Mitsubishi Galant Brake Shudder
MITSUBISHI
DANASH
2003 mitsubishi galant, 4 cyl, 120,000 mi,
the rt front wheel shudders when braking from high speed, is it possible that it's cv joint.
I have a 94 eclipse 4 cyl, new pads ect does the same thing.
In short is the vibration a typical cv problem??
I have also noticed a hum from the drive train recently on the 2003 and a clunk on accelleration on the 94
Aug 11, 2007 at 5:09 AM
GREASE MONKEY
  • 23 POSTS
Did you turn the front rotors ? Rotors are so cheep now new ones instead of turning is recomended. Sounds like a rotor out of round or not true and has high spots in it. Let me know.
Aug 11, 2007 at 1:34 PM
Suggested Repair
Inspect the front brake rotors for being out of round or having high spots. Replace the rotors with new ones rather than turning them, since new rotors are inexpensive.
Conversation Summary
The owner of a 2003 Mitsubishi Galant reports right-front shudder when braking from high speed and asks whether a CV joint is the cause. A 1994 Eclipse with new pads has the same symptom, plus a drivetrain hum on the Galant and a clunk on acceleration on the Eclipse. The expert says the shudder sounds like an out-of-round rotor with high spots and recommends new front rotors instead of turning them.
