98 Eclipse won't start
1998 MITSUBISHI
ADAMANTINE75
I have a 1998 Mitsubishi Eclipse GS, 143000 miles that will not start. It stopped while going 50 miles an hour, and now will not restart. The starter was bad, and I replaced that...Ignition coil was cracked, and I replaced that. Car will try to start, but will not fire/turn over. Fuel pump is fine.
I need help!
Dec 6, 2006 at 7:56 AM
JUGGALOHO
check the ASD relay, starter relay and ecu
Dec 7, 2006 at 10:07 PM
A_EAGLE2007
Hey, im justin an i have a 98 eclipse too and the same thing happened to me and it turned out to be the timing belt, so i hope that helps
Dec 12, 2006 at 10:29 AM
BLACK WIDOW
  • 5 POSTS
[quote:cbbfbd5024="adamantine75"]I have a 1998 Mitsubishi Eclipse GS, 143000 miles that will not start. It stopped while going 50 miles an hour, and now will not restart. The starter was bad, and I replaced that...Ignition coil was cracked, and I replaced that. Car will try to start, but will not fire/turn over. Fuel pump is fine.
I need help![/quote:cbbfbd5024] I AM HAVING THE SAME PROBLEM I REPLACE EVERYTHING AND STILL NO SPARK
Dec 14, 2006 at 12:06 AM
BLACK WIDOW
  • 5 POSTS
[quote="a_eagle2007"]Hey, im justin an i have a 98 eclipse too and the same thing happened to me and it turned out to be the timing belt, so i hope that helps][/quote
WHAT WAS WRONG WITH YOUR TIMEING BELT I HAVE A 1998 GS ECLIPSE THAT WONT GET SPARK
Dec 14, 2006 at 12:13 PM
