95 mighty max
1995 MITSUBISHI
FAH
I have a 95 mitsubishi mighty max with 250000 miles on a 4 cyl 2.4 engine. Today when I tried to start my truck the dummy lights came on like normal but it would'nt start, no clicks ,nothing. I push started it and got it home. When i got it home I shut it off then hit the ignition and it started right up.My question is, is there a clutch/starter linkage that may have caused this or is this the sign of a dying starter solenid?
May 30, 2007 at 6:53 AM
JAVA MOTORSPORTS
  • 52 POSTS
They have a clutch switch that will not let the truck start if the clutch is not pressed all the way down. Sometimes they short out and will not let the truck start . However it could still be your starter i would try the switch first.
May 30, 2007 at 8:38 AM
