94 mitsubishi mirage hall effect distributor
1994 MITSUBISHI
WORKNFOOL
Afternoon Guys,
My daughter just picked up a 1994 mirage dx 1.5L, M/t, no power acc. with 140,000 mi.. The dam thing isn't getting spark or injector ground signal. I have power at the injs. and it turns over fine. is there a pin-out for ohm values on the hall dist. this beast has on it so I can test if it is the dist or the ECM. HELP ! anyone got a wiring diag. and don't say autizone they don't have squat on this car !
Dec 21, 2006 at 11:40 AM
MELLEFSON
check ignition module dont screw with the computer thats the last thing you want to check
Dec 28, 2006 at 5:39 PM
WORKNFOOL
Ya' Know, This is a fantastic set-up on the internet.....you can find out any information you needed on any subject you had.
You see.....I also am a mechanic with over 35 years experience but it just so happens I never had to work on Mitsubishi's.
Dec 29, 2006 at 7:42 AM
