So the other day i was driving my 93 Mitsubishi 3000GT SL and the clutch was not engaging until it was almost touching the ground, normally my clutch engages close to the top. As i continued to drive, it got a little better, engaging a little further out from the floor, but it was still pretty bad. Then the next day, i went out to turn on the car, and after it warmed up a enough, i went to put it in gear. The clutch was again not feeling like it wanted to engage until it hit the floor, but the biggest problem was that i couldn't put the car in gear. I tried all gears, none worked, i pumped the clutch and it got no better. So i turned the car off and had to bum a ride from someone else. Later that day i tried again, same thing, but now the clutch sticks to the floor, i have to put my foot under it to pull it out, most of the time, about 1 in 15 pumps now it will pop out itself. One of my roommates tried helping me, he found that there is a fluid leaking down the back of the clutch pedal, but he could not find the where the clutch is in the engine, so he couldn't see the problem. I don't know much about cars, so i feel helpless right now. It is VERY important that i get this fixed ASAP, so any help is much apreciated. I would take it to a shop, but since the car won't go into gear i can't get it anywhere. If anyone can help please let me know.
Nov 20, 2006 at 11:16 AM
