3000gt problems
2012 MITSUBISHI
MSTONE2005
i have a 94 3000gt non turbo. the runs great, except 2 things. there is a white smoke coming from the exhaust, just enough to see, and doesnt go away from warming up the car (catalytic converter) there is also apparently an oil leak. i have to add oil about once a week - 2 weeks. And with the oil leaking the oil pressure gauge goes down, but never over heats, and im not leaking/ losing coolant. Any idea what could be the problem?
Jun 20, 2007 at 11:23 AM
JAVA MOTORSPORTS
  • 52 POSTS
Sounds like your engine is worn and oil is leaking past your piston rings and burning the oil you are missing. A worn engine would cause the oil pressure to be low and the smoke you see.
Jun 21, 2007 at 12:41 AM
