2004 Other Mitsubishi Models Pinging, whats causing it?
2004 MITSUBISHI
50,100 MILES • 6 CYL • FWD • AUTOMATIC
CHAMORITA
I have a 2004 mitsubishi endeavor, I believe 6 cylinder engine. I do not know anything about a cars engine. I've been having a "pinging" problem with my car for sometime. Have taken it in and was adviced to use an octane booster. Which I have and its reduced the pinging slightly, but I can't get rid of it. I'm wondering exactly whats causing it. It happens when I excelerate. Also how much should I anticipate paying to get this problem repaired? Thanks so much for your time.
Oct 26, 2008 at 7:16 PM
  • 75,988 POSTS
Hi chamorita and welcome to 2carpros-
Hafa adai
You tried the octane booster didn't worked-I recommend you have the knock sensor and EGR valve checked/tested-
The knock sensor if it doesn't sense the pinging/detonation is will not retard the ignition timing
The same as the EGR valve-if it doesn't open -combustion chamber will rise and the level of oxides of nitrogen will also increase that will make the engine ping/detonate also an overheating engine-
Oct 26, 2008 at 7:48 PM
CHAMORITA
thankyou for taking the time to answer my question. I appreciate it! :)
chamorita
Jan 28, 2009 at 2:53 PM
