2004 Other Mitsubishi Models
2004 MITSUBISHI
BLKCEASAR
Steering problem
2004 Other Mitsubishi Models Automatic 98700 miles
I havea couple of questions. My 2004 Mitsubishi Endeavor is a problem all of a sudden. A body shop repaired a dent in the door and now I've got two problems. First, whenever I turn my wheel sharply as if to make a turn or parallel park the wheel is impossible to turn. There is power steering fluid and no leaks so what could it be? Secondly, my care now won't start at all. I turn the key and get nothing, my lights are dim, and my remote control keyless entry won't work! Heck I can't even lock the door with my key! What's going on here?
Nov 24, 2008 at 7:24 AM
  • 31,937 POSTS
HI there, for the steering, check that the drive belt is tight and is the pump making a noise on lock, or is the steering not moving at all, as for the power problem, get the battery load tested and replaced if found to be faulty, have the alternator charge rate check and make sure that the panel shop have re tightened all battery terminals and that the earths are tight and clean, start here.
mark (mhpautos)
Nov 24, 2008 at 12:17 PM
