2003 Mitsubishi galant
2003 MITSUBISHI
AZCARDINALS602
  • 10 POSTS
122,000
engine size v4
every time when i come to a full stop and then try to push the gas to go my car like studers before taking off like if its clog or something it only happens when trying to take off at the begining (like 1sec or so) please help if you can thank you pls email me at
s.contreras@cox.net
have a great day
santiago contreras
Sep 5, 2007 at 11:03 AM
MERLIN2021
  • 17,250 POSTS
You might want to try a tune up. Maybe clean the throttle out. and the injectors would be nice....
Sep 5, 2007 at 11:25 AM
AZCARDINALS602
  • 10 POSTS
[quote:cf446082a0="merlin2021"]You might want to try a tune up. Maybe clean the throttle out. and the injectors would be nice....[/quote:cf446082a0]
__________________________________________
hello i changed the sprak plugs on my car and it doesnt do it any more thank you so much for your help !!!!
i have more quetion for you
122,000 miles
4 cly
the only thing now with the car is it idles a little bit low is there a way to fix that ? oh ya i havent done the( Maybe clean the throttle out. and the injectors)
could that make the idle be low ?
and to clean the throttle out. and the injectors does it have to be done professional ?
is there some where to tune idle ?
Sep 10, 2007 at 6:38 AM
MERLIN2021
  • 17,250 POSTS
I must go for Doctors visit...will look it up on my return!
Sep 10, 2007 at 7:25 AM
MERLIN2021
  • 17,250 POSTS
Yes there is a way to do it however it is not recomended! If you have any codes, check engine light on, or if the idle is unstable or rough, then the IAC, or idle air controller should be replaced!
Curb idle warm engine is 600-800 rpm.
Sep 10, 2007 at 9:15 AM
AZCARDINALS602
  • 10 POSTS
122,000
engine size v4
had another quetion for you .
every time i come to a stop my brakes grid
i have check the pads and they still have about 4-6 months left on them why would they still be grinding ? thank you so much for all your help !!!!
i have also replace front rotors !!
Sep 18, 2007 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
You have checked all 4 wheels?
The other thing is, with a floating caliper design, you may be hitting the rust line when braking! Not dangerous, only annoying! Machine the rotors to solve...
Sep 18, 2007 at 11:08 AM
AZCARDINALS602
  • 10 POSTS
thank you so much again again lol thanks man!!!!
aslo could it be my rear drums?
Sep 18, 2007 at 12:19 PM
