2001 Other Mitsubishi Models how do I change sparkplugs
2001 MITSUBISHI
JBALDWIN
Electrical problem
2001 Other Mitsubishi Models 4 cyl Two Wheel Drive Manual
Apr 22, 2008 at 1:36 PM
GUS540I
  • 11 POSTS
What kind ignition system do you have? If you have spark plug wires then you need to remove them first and then remove the plugs, if you have coil over plugs the coil packs need to be removed first, (usually a couple of 10mm bolts), before spinning out the old plugs. When re inserting the new plugs be certain to put anti seize on the threads in order to avoid complications down the road
Apr 24, 2008 at 12:27 AM
