i have a shogun pinn gdi clutch pedal has gone to the floor hydrolic clutch can you help
Aug 12, 2008 at 10:57 PM
✓Experienced Mechanic
Hi there,
Check the hydraulic fluid, if its gone, check the slave cylinder at the gearbox for a leak, (pull back the rubber dust boot) if it is wet it is faulty, also check the master cyl, this is a bit harder but look under the dash and see if there is any fluid leaking where the pedal push rod enters the master cyl, start here.
